CVP Call Studio 10.5 - Project Tabs
ryschule
We are upgrading from CVP 9.0 to 10.5. After upgrading to Studio 10.5, I noticed all of the project tabs are labeled 'app.callflow'. Previously, the tabs were labeled with the project name, making it easy to keep organized. Now, if an engineer has multiple projects open, it is difficult to identify which tab belongs to which project. Is there a fix for this?
Thanks!
Ryan
dipmehta33
Hi Ryan,
If you roll your mouse over those app.callfow, it would display the app name there.
dipmehta33
Hi Ryan,
