ā08-18-2021 10:12 AM - edited ā08-18-2021 10:16 AM
hi everyone
in my demo , i install UCCE 12.6 and CVP 12.6 and VVB 12.6
now the call can call in the ICM but caller hear the error prompt.
next is my config:
in my ICM script i use a "set variable" module to set : concatenate("application=SGIN;callid=",Call.user.media.id)
and then i use call studio create a script named "SGIN".
the SGIN script deployed in CVP VXML server ,on VVB I create a new application named "SGIN" and use the script CVPComprehensive.aef and creat trigger .
i use VVB real-time report to check ,when i call in ,the report can display i triggered the VVB application "SGIN", but i hear the error prompt.
how i can check this problem???
thanks very muck
Solved! Go to Solution.
ā08-19-2021 03:33 AM
this problem is resolve,
thanks everyone
the error is i not set default VRU in ICM system information...
ā08-18-2021 10:43 AM
1. Every VXMLServer comes with MyApp. Try modifying the ICM script to "application=MyApp" (and you do NOT need to pass the callid). See if this works. If it does, then there's an issue getting to SGIN. If it doesn't work, then there's a different issue.
2.If MyApp works. Then for SGIN, if you hear the male error message, it's reaching VXMLServer.
You can look in VXMLServer/logs/globalCallLogger - to see if it says there's a problem with the URL or finding the app.
3. If that log is empty, then perhaps the call is reaching your app.
Look in the log: VXMLServer/applications/SGIN/logs/ActivityLog - you'll see how far the call got. Then VXMLServer/applications/SGIN/logs/ErrorLog for the actual error. If you see 'error.badfetch.http prompt url null fialed' - then it indicates that the Voice Browser can't find your audio file to play. Chances are that you didn't configure the Default Audio Path URI for the VB to find your audio files.
4. You can also look in the CallServer log: C:cisco/cvp/logs/VXML/error.log - if there's an error with vxml server or in the app - it'll show up there.
ā08-18-2021 04:22 PM
thanks for you reply.
i'm try change the ICM application name to "application=MyApp"ļ¼in my case there no script named MyAppļ¼, and then call in,but still hear error propmt.
when i transfer application=SGIN, the CVP log: VXMLServer/applications/SGIN/logs is empty. the C:\Cisco\CVP\VXMLServer\logs\GlobalCallLogger is also empty
i can see the call is in VVB application ,but not call the CVP script
thanks everyone
ā08-18-2021 04:43 PM
next is my log, i think this problem is VVB can't call the script in CVP. i first config VVB ,before i use 3900 router for VXML gateway is fine.
callserver log.txt is C:\Cisco\CVP\logs CVP.log (not error log)
call-vxmllog.txt is C:\Cisco\CVP\logs\VXML CVP log (not error log)
VVB_application.png is display the vvb real time report
you can search "application=SGIN"
ā08-18-2021 10:57 AM
you already config sip server group and pattern??
how about if you try with simple script or sample script to run media (run external script) it's work??
ā08-18-2021 06:05 PM
ICM run external script" GS, Server,V", CVP script audio is use callserver local tomcat path .
i use CUCM register a soft phone , and CUCM sip trunk to CVP callserver.
CVP config sip static route to vvb
ā08-18-2021 06:48 PM
ā08-18-2021 08:14 PM
YES my vru label is 15, in CVP call server i change this to 15
i try 10 digits now
ā08-18-2021 08:38 PM - edited ā08-18-2021 08:43 PM
I want to known how to check the VVB log.
Can i check the vvb handle log? i don't knonwn why the VVB can't call CVP script
In VXML Gateway i can use ādebug voice application vxmlā to see
