CVP Record Element-Noise at end of audio
mike.robinson
We are using CVP 11.6.  When using the CVP Call Studio Record Element, there is always a short noise at the end of the audio file.  We've tried muting the phone when pressing # to end the recording but the noise still appears at the very end of the audio.  We also tried other keys besides # - all result in a short blip at the end of the audio.
Has anyone experienced this before?
ptindall
Sounds like the length of the file might be inconsistent with the duration of audio captured.  Try a test using a max duration setting and see what the file contents are.  Also try to record silence or a steady tone so you can identify in the file contents where the audio should have ended and see if there's a piece of junk on the end.   This won't solve your problem but might reveal what's happening and whether there's an underlying defect.
