CVP rest_cient element: header field format and example
jgass
I am configuring the CVP 11.0 rest_client element for a http POST request with a JSON path (payload). Is there any information on how to configure header field in the customer element? I need to pass three values (including credentials) as part of the header information to the REST web server?
Working examples would be great!
Jason
Click on the Headers value field and open the pop-up for entering/editing headers.  See screenshot.
Quigath
I have one as a GET if it's useful:
You should also check out the programming guide. It should have all the details you need for customizations.
jgass
Thanks for replying back - the problem I have is that I am not sure what is the format is required for the values in the header field.
For example, the VXML user guide for 11.0 has an example required for the format in the JSON path:
 {"community": {"name":"public","snmpversion":"V1","acceptfromanyhost":"true","accessprivilege":"readOnly","servers":{"server":"IP
address}}" }
But there isn't any help / guidance for the header field of this element?
Jason
