Is Symantec Critical System Protection (CSP) compatible with UCCE 8.5
cjdavis7782
Level 4
Level 4
Does any one know if Symantec Critical System Protection (CSP) compatible with UCCE 8.5 (CVP, HDS, RGR, and PG)?
anchoudh
Level 9
Level 9
Hi Curtis,
Please check in the below comp matrix.
http://docwiki.cisco.com/wiki/Unified_CCE_Software_Compatibility_Matrix_for_8.5%28x%29
Hope it helps,
Anand
Please rate helpful posts !!
Hi Anand,
For UCCE the information on third party software is checked in Bill of Materials guide and not in comp matrix.
Curtis,
Please check the BOM for UCCE 8.5
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/icm_enterprise/icm_enterprise_8_5/reference/guide/icm85_bom.pdf?referring_site=bodynav
If the guide specficaly states about the software it means that it has been tested and will be supported. If not it implies that the software has not been tested.
Thank you
Anuj
Gajanan Pande
Curtis,
You might want to refer " Cisco Customer Contact Software Policy for Use of Third-Party Software " which has guidelines for Antivirus Softwares to be used with Cisco UC/UCC products.
GP.
Pls rate helpful posts by clicking on the stars below the post !!
