JSON in UCCX Script
Hi Team,
Can you guide me how to create a JSON in UCCX script.
Jijesh
52 Replies 52
Crate string variable INC with string “INC”. Then when you get the digits do a set variable INC = INC+DigitsVar.
david
@david.macias
I am configured the variable .screenshot below.
Results below. Only taking the number
No quotes just INCOutput = INC + INCresult
david
Hi David,
I used the set value and created the different varibale (INC + "") joined together and added the value in Rest call . It is getting the correct result.
Jijesh
@Roger Kallberg
I am getting the null value while validating the employee ID. I have set the "if" condition but it is not matching can you suggest. How to match the "null " value
Your expression is checking if Employee_ID is the string "null". Try Employee_ID == "" or Employee_ID == null.
david
Jijesh
@david.macias
Employee_ID == null worked and I tested now. Thank you David
