PostCall Survey help with UCCX7
joguevil2008
Level 2
Level 2
I need your guidance because I need to deploy a postcall survey in a Contact Center using UCCX 7 scripting. I have limited knowledge in scripting and don't really know how, or if it is possible, to pass the information I need between the different scripts or parts of the process. I have read several posts about this but I remain lost.
Just to clarify the scenario, we have a Contact center attending different queues, with different skills. So, what I want is adding a button on the agent CAD to enable a transfer to the survey application (that's the easy part). What I must pass in this process is the name or ID of the agent, the attended queue and the ID of the attended call. The survey only has 2 questions.
Once in the survey, is it possible to store the information of the answered questions, and the information got from the transfer in custom Variables? If so, How can I do it? What I'd like to do is avoiding the use of an external DB as we only have 2 questions to store.
Anyway, if you have some other suggestion please tell me.
I would be grateful If you could help me
Thank you in advance
Jonathan Schulenberg
You need to store all of these details to the contact's session prior to the original script ending. The easiest way is to put it within the Connected branch of the Select Resource step.
Select Resource
  Connected
    Get Contact Info <-- Get the session ID
    (Optional) Get User <-- Specify the Resource username value the Select Resource step gave as output
    (Optional) Get User Info <-- Get whatever other data points you want about the agent
    Set Session Info
      Store the agent's username
      Store the CSQ name
      Store whatever else you love.
In the survey application you should be able to use Get Info to find the session ID again and then Get Session Info to pull the variables back in. Don't forget that the session is NOT stored to the database. Anything in the session is lost 30 minutes after the call hangs up. Use Set Enterprise Data to keep it.
Yes but you're limited to the 10 call variables that get stored to db_cra. Remember that there are only ten system-wide so be careful not to mix data in the same column. The variable is a VARCHAR(40) field so you can stuff multiple values into one field as long as you decide what your seperator is going to be.
Please remember to rate helpful responses and identify helpful or correct answers.
6 Replies 6
Select Resource
  Connected
    Set Session Info
      Store the CSQ name
Nicely explained Jonathan (+5). Attaching a sample Survey Script to this thread as well just in case it helps any one who visit here to find the solution for their Post Call Survey thing.
Deepak
Hi Deepak,
Thank you very much for sharing the script. In my case I would like to store the information from survey in custom variables. Would you have a example script for that ?
Luis.
Hi Deepak,
Attaching also two scripts that I am working for a Post Call Survey solution. The "MainScript" is used to receive the calls in a firts moment and the "GenericSurvey" is for the call survey. I am currently facing an issue to send some info(AgentExt, AgentID, CSQ, etc) from the first to second script.
Could you please take a look at both and tell me what´s wrong with them ? I suppose something with Set session Info step but I don´t know what exactly.
Luís.
Hi Jonathan,
Regarding your post above, The "Get User Info" step in my script is not returning back the agent information as expected. I just receive the message " GetUserInfoStep: Agent: is Null" during the reactive debug. Could you please take a look and tell me what´s wrong with that ?
Luís.
Hi Jonathan,
I am also facing the same issue, AgentID and CSQ information is not passing to the post call treatment script.
Did you get the answer for your query?
