Transform Document help - CCX
Andrew Grech
Hi, please see my script attached.
1. User calls into script
2. Sets status to true or false
3. User is authenticated (hardcoded at the moment)
4. Keyword transform document changes value to true or false as per above.
5. Document is uploaded
The script is completing however the result from transform document are not uploaded. It simply uploads the template with %vaule%
I have also tried without the .toString()
Any help would be much appreciated
Andrew
Samuel Womack
Level 5
Level 5
On first glance..does the FilePath of the DOC (result) need to be (in the Upload Document Step):
"/brisbane/test/emergency.xml"
Im unsure I was using the script repository as a guide.. It's actually uploading to my file language root but thats ok..
Gergely Szabo
Hi Andrew, could you try removing the Create XML Document step?
G.
