03-23-2014
10:29 PM
- last edited on
03-25-2019
07:25 PM
by
ciscomoderator
Hi, please see my script attached.
1. User calls into script
2. Sets status to true or false
3. User is authenticated (hardcoded at the moment)
4. Keyword transform document changes value to true or false as per above.
5. Document is uploaded
The script is completing however the result from transform document are not uploaded. It simply uploads the template with %vaule%
I have also tried without the .toString()
Any help would be much appreciated
Andrew
03-24-2014 03:50 AM
On first glance..does the FilePath of the DOC (result) need to be (in the Upload Document Step):
"/brisbane/test/emergency.xml"
03-24-2014 05:03 AM
03-24-2014 05:13 AM
Hi Andrew, could you try removing the Create XML Document step?
G.
