Translational Route Problem
chinmay.b
Hi Guys,
I have a DialedNumber=1991 with routing client as CiscoCallmanager.
If the agents are available call gets routed to the agent .
But if the agent is not available I am trying to send it to the VRU using the Translational route but it doesn't work.
(label defined for VRU is again 1991)
Trace:--
> DialedNumber (1991) using CallType (AndSupp - 5002)
Start #1
Default\TransRouteAndITSupp {All Customers} (version 1)
Select #2
Translation Route to VRU #4
Select min of:
*ANDQM01.AndSupp = 2
> No peripheral target available for translation route TR_ANDQM01 (ID 5022) with routing client ANDCCM (ID 5000).
Can anyone help me on this.
Thanks in advance
chinmay
7 Replies 7
jond
You need to define a separate distinct range/pool of dialed numbers/cti route points for the Translation Route. These numbers should only be used for Translation Routing. You'll need more than one depending upon call volume and IVR port sizing.
erestes
