06-01-2010 01:41 PM - edited 03-14-2019 05:49 AM
Does UCCX7 support SQL Views instead or a table? I see under the DB READ step that I can see all the available Views for the user but I'm getting a SQL connection error when I run reactive debugging. My SQL statement returns 1 row so I know the statement is accurate.
06-02-2010 01:56 PM
Yes, it does support Views. In fact, using a view is a valid way around the current limitation of not being able to read records from different tables in one SQL statement.
i.e., This wont work in the editor:
SELECT a.name, b.age FROM people AS a, birthdays AS b WHERE a.name = 'Anthony'
Message was edited by: Anthony Holloway - Wow this forum software really upsets me.
01-27-2016 08:01 AM
Hi Anthony,
can you please tell me, how to edit the jdbc driver URL in case I use a db view?
My customer gave me access to a view and I can't setup a successful db connection.
Many thanks in advance!
Best regards,
Michael
p.s.: In the meantime we're using Rel. 10.6 :- ))
01-27-2016 08:16 AM
I'm sorry, but I don't know the answer. I would ask that you post this question in your own topic thread for wider visibility and help.
01-27-2016 08:39 AM
Are you following the instructions mentioned in the below Admin Guide to setup DSN connection:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_10_6/config/guide/UCCX_BK_CEC562D1_00_cisco-unified-ccx-administration-guide106.html
BTW which DB server are you using, make sure it is one of the supported one as mentioned in the below Compatibility Matrix:
http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_for_10.6(x)_and_Service_Releases
Deepak
01-27-2016 08:45 AM
what is the error message you are getting?
Are you able to create the JDBC connection or does it fail, too?
G.
