02-24-2010 08:24 AM - edited 03-14-2019 05:20 AM
How can I troubleshoot this issue?
Doesn't happen all the time but every once in a while.
UCCX 5.0.2 SR2
05-22-2020 01:28 PM
10-01-2010 01:14 PM
Check the menu prompt option in script and make sure that interruptible is selected to Yes under general tab.
10-03-2010 08:46 AM
I'm aware of this, but don't you think that if did this, my prompt will not be played to the end, so my caller will hear half of the prompt !?
10-04-2010 01:03 AM
That's true - but generally that's what you would want with a queue prompt.
Barge In - Determines whether the caller can interrupt the prompt -you can set this to 'No' to prevent the caller pressing a key and skipping the prompt
Interruptible - Determines whether the system can interrupt the prompt -e.g. to do the transfer to the agent
All steps that are hit when the contact is in-queue (i.e. from when the 'select' step is hit) should be interruptible, otherwise the system must wait for the prompt to be played out before it can transfer the call.
If you have a prompt that must be played out in full (for example a recording warning, or regulatory announcement) then this should be played before the select step, and only interruptible prompts should be played after the select step.
Aaron
Please rate helpful posts...
10-05-2010 01:31 AM
Thanks guys for your assistance, really appreciate your prompt replys.
Before i try your suggestions (make prompts interruptable in the queue), i have reviewed my script and found that i have 2 delay steps (each of 1 sec) that are configured as interruptable, and i already got my prompts as un-interruptable, so i decieded to make the delay also un-interruptable. (these delays are used to give a gap between prompts)
It has been 4 days for now, and the issue didn't surface again... as soon as the problem hit again, i will try your suggestion and update the post.
10-05-2010 03:31 AM
Your terminology is confused a litte.
Each step has a property 'Interruptible'. It can be set to 'Yes' or 'No'.
All queue steps should have it set to 'Yes', and would then be interruptible.
Other steps may be set to 'No' if you like, and would then be considered un-interruptible.
If you have set your delay and prompt steps to un-interruptible, then you will still have the problem. If a call comes to the queue, and an agent is available immediately, the steps will not execute, so you won't notice the problem until the queues build up at a busy time.
Aaron
10-06-2010 12:33 AM
Hi Aaron,
I know i have been stobborn on this but I have done a some research and didn't find yet a document that recommends to make prompts interruptable in queue. I was reading the "Getting Started with Scripts" guide from Cisco
check page 150 - "About Script Interruption". I couldn't find a clear direct statement that talks about my issue but i found the following:
"If an interrupting event happens when the script is not currently interruptible, the script is automatically interrupted whenever it becomes interruptible again."
On the other hand, my issue was surfucing when agents are all available and no one in queue!!! Anyway, I will be preparing an alternative script that flows as per your recommendation, just in case.
Also if you have more documents you would refere to me, i would appritiate that.
09-04-2012 05:11 AM
Hi Aaron,
i contacted TAS with issue, that you describe here. I should to be ashamed.. :-)
Keep helping.
Patrik
