10-24-2009 07:04 AM - edited 03-14-2019 04:46 AM
Dear all
I have UCCX version 7 , when i want to install on my MCS it returns an error that the server is not Cisco approved
while my box is MCS with win-os 2003.1.2
any idea?
10-24-2009 10:12 AM
Is that specific MCS part number and OS version listed on the compatibility guide? My guess is you have the wrong MCS server.
10-24-2009 11:19 AM
no its the correct mcs
right now i have also cisco unity installed
it mcs7835h2
10-24-2009 12:48 PM
Are you re-installing from scratch using the Windows Server 2003 OS disk included with UCCX7 or just trying to install UCCX on a server that already has Windows 2003 installed? - maybe the OSA that shipped with Unity?
If the latter then that will not work - you need to use the OS supplied with UCCX.
12-31-2009 06:53 AM
Is that correct James.
I as becasue the only way I can get an HP DL320 G4 to build is with the Unity build disc.
If it must be the UCCX build disc, I'll have a look for it.
Weird as the only erro rthe log says is not enough disc space. Needs at least 4GB free when the box has over 65GB free.
Cheers,
NeilW
