Unable to dial Manual Outbound calls from Finesse using *XXXXXXXXXXX
durraze khan
Dear All,
The manual Outbound calls starting from *XXXXXXXXXXX are dialing from IP Communicator, but from Finesse the manual Outbound calls *XXXXXXXXXXX are not dialing as it gives message that "Call could not be completed".
Looking forward for the response.
Best Regards,
Durraze Khan
UCCE Support Engineer
2 Accepted Solutions
eric.butcher
I don't think any part of UCCX has ever been able to dial *.
Used to always have to use a non-* prefix in UCCX scripts for rerouting to a mailbox when CUCM systems were configured to use *XXXX to direct-dial a mailbox.
I just tested with my finesse implementation and I cannot dial any pattern with * either, though multiples are defined in CUCM.
* and # are not supported in the Finesse API in the "toAddress" field.
Simple answer: not at this time.
https://communities.cisco.com/docs/DOC-48537
6 Replies 6
Chintan Gajjar
Level 8
Level 8
check the agent desk setting, does it have access to dial the calls outside?
Murali_DS
Does the agent have a separate extension for handling customer calls / same extn used for both internal and customer calls?
Does the agent dials a CTI RP / Extn. If the agent has a seperate extn for CC, the translation Pattern
can be validated.
durraze khan
Do Finesse supports special characters?
BR,
Durraze
eric.butcher
Hi Eric,
Thanks for sharing the response, we are trying to dial manual OB calls from Finesse using *,# and  1* prefix followed by number. Irrespective of UCCX, do Finesse support the special characters above?
Looking forward for your response.
BR,
Durraze
