webview report problem
Hello I need help, When I open report from Webview Iget this message.
There was an error running your report.Please try againd and contact your webview administrator for further information.
Error Message:ICMDW Erroropenreport():LibraryExport Failed- arg_path:C\icm\om\aw\custom\agentteam\ppb050.pbl arg_report:peragt26_day_consolidated
can anyone help me?
Thanks.
Gajanan Pande
Santiago,
There are several internal bugs ( bug details publically invisible ) matching the symptom. The best approach would be to open a TAC case for precise troubleshooting.
CSCso04595
CSCsk52602
GP.
Pls rate helpful posts !!
Thanks all for your reply, The problem is resolve when I reload the server HDS/AW/webview .
Best Regards.
Dass Prakash R
are you facing the errors for all the reports or for speific type of reports? Please elaborate your issue
Gergely Szabo
Santiago,
does the pbl file name sound familiar to you, I mean, did you try to modify it?
G.
