Cisco Nexus 7K Port-channel
UniWAQ
Hello All,
I want to reset configuration for the interface Ether2/4 and Eth 3/2 ,as these interfaces are uplink for fex, but I am getting following error:-
pro(config)# default interface Eth2/4
Interface config wipeout failed for Ethernet2/4 (ifindex: 0x1a083000)
I found one document about it , Do I have a same problem or no ?
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtk83899/?rfs=iqvred
pro# show port-channel summary interface port-channel 102
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
        M - Not in use. Min-links not met
Group Port-       Type     Protocol  Member Ports
      Channel
102   Po102(SU)   Eth      NONE      Eth1/2(P)    Eth1/4(P)    Eth2/2(P)
                                     Eth2/4(D)    Eth3/2(D)    Eth3/4(P)
pro(config)# show run interface port-channel 102
interface port-channel102
  switchport
  switchport mode fex-fabric
  fex associate 102
pro(config)# show run int Eth2/4, eth 3/2
interface Ethernet2/4
  switchport
  fex associate 102
  channel-group 102
interface Ethernet3/2
  switchport
  fex associate 102
  channel-group 102
WAQ
balaji.bandi
I have not tried it, but you can test and let me know below alternative method works.
config t
shutdown
no fex associate 102
 no channel-group 102
 shutdown
if above success.
then default interface
BB
mojafri
Hi @UniWAQ,
This is a duplicate post: https://community.cisco.com/t5/data-center-switches/nexus-7010-port-channel/m-p/3745619#M3706
Have you tried what i mentioned earlier?
MJ
