Disable Weak Cipher in ACI Fabric
Recently received a few Linux-based vulnerabilities for disabling SSL/TLS weak cipher disabling, i have received these vulnerablities for all ACI Fabric devices  but not sure how to fix this, Any document for disabling the same?
Dawei
Hi Dinesh,
If you have CVE numbers, search it via the below link, you will find out the workaroud or fixed version if it's a known issue. Otherwise, open a TAC case to check it.
BTY, not all scanned vulnerabilities are affected.
Cisco Security Advisories
https://tools.cisco.com/security/center/publicationListing.x
