How can i disable the BPDU guard on a single port of nexus 2k (2248TP-E).
currently port is configured as spanning-tree port type edge.
while i try to make the port type as normal its also not taking, showing "ERROR: Command not supported on fex port"
Also i tried with disabling command but no luck.
spanning-tree bpduguard disable
ERROR: Command not supported on FEX interfaces. BPDUGuard is enabled by default for FEX interfaces
Solved! Go to Solution.
Hi there,
You cannot disable BPDUGuard on a FEX HIF; however, you can enable BPDUFilter on the interface and that way when you receive a BPDU from a connected switch, it is filtered and thus cannot trigger BPDUGuard.
Do understand the risk this poses as you're essentially disabling STP on this port and would have to guarantee a loop free network on the connecting switch in some fashion.
Fabric Extenders are intended for Host facing interfaces -- They were not built for switches to be connected to it and their buffers are not necessarily deep so do keep performance in mind as well.
Nexus# conf t Nexus(config)# int e101/1/24 Nexus(config-if)# spanning-tree bpdufilter enable Nexus(config-if)# end Nexus# show run int e101/1/24 !Command: show running-config interface Ethernet101/1/24 !Time: Fri Oct 19 15:40:24 2018 version 7.3(3)N1(1) interface Ethernet101/1/24 switchport access vlan 111 spanning-tree bpdufilter enable <<<
Thank you,
Hi Muhammed,
Have a look to below link:
**All Fabric Extender host interfaces run as spanning tree edge ports with BPDU Guard enabled and cannot be configured as Spanning Tree network ports.**
Please rate if you find it helpful.
MJ
Thank you for the information but i am looking for the solution on the nexus 2k box itself, which i could not found yet. The only solution i found is that i have to move this legacy device connectivity from 2k to any other switch.
Hi there,
Thank you,
Please add this to the Nexus Configuration Guides because they all now say after NXOS 5.2 or 7.x the following......
