2921 with 4FXO can't transfer the call from PBX
c1szhibin
Hi guys,
I have a third-party PBX connected to a brand new 2921 with 4FXO. All the phones are registered to this PBX.
When I called the phone on the branches, I was supposed to dial "10", (wait till the call transfer from pbx to voip gateway ) and then dial the extension number (e.g. 6xxx, 7xxx). The voip gateway would transfer the call by the dial-peer over IP WAN.
After I replaced the voice gateway with 2921, the call failed. It sounded like the the call didn't transfer from pbx to 2921 after I dialed "10".
People from the branches could call my phone, and I couldn't call back.
Anyone met the situation like this? I'll be so glad the somebody could give me some hints to solve it.
version 15.4
hostname DuiVG-HK
boot-start-marker
boot-end-marker
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
voice-card 0
dspfarm
dsp services dspfarm
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711ulaw
license udi pid CISCO2921/K9 sn XXXXXXXXXXX
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.0.252 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.0.252
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.0.250
snmp-server community netwoocin RO
control-plane
voice-port 0/0/0
cptone HK
voice-port 0/0/1
cptone HK
voice-port 0/0/2
cptone HK
voice-port 0/0/3
cptone HK
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 7 voip
destination-pattern 7...$
session target ipv4:192.168.1.252
dtmf-relay h245-alphanumeric rtp-nte
no vad
dial-peer voice 6 voip
destination-pattern 6...$
session target ipv4:192.168.2.252
no vad
dial-peer voice 9 voip
destination-pattern 9...$
session target ipv4:192.168.43.26
no vad
dial-peer voice 81 pots
destination-pattern 8..$
port 0/0/1
dial-peer voice 82 pots
port 0/0/2
dial-peer voice 83 pots
port 0/0/3
dial-peer voice 84 pots
port 0/0/0
gatekeeper
shutdown
Manish Gogna
Can you run a "debug voice ccapi inout" on the gateway to see if the call is even making it to the gateway.
Manish
saif musa
Level 4
Level 4
Just for clarification please..
The current status is people at branches can call ( 8... ) while people at your branch cant call ( 6... ) and ( 7... ). Is that right ???
