09-09-2012 03:32 PM - edited 03-16-2019 01:06 PM
Hello all
I am working on my first VOIP/UC project and I'm running into some trouble out of the gate.
I have a 3725 router and access to two IOS images:
advipservicesk9-mz.124-25d and ipvoice-mz-124.25d
I've installed a NM-HD-2V card into the 3725 but when I install the VIC-2FX0 I'm running into issues.
Show Diag yields:
WIC Slot 1:
FXO Voice daughter card (2 port)
WIC module not supported/disabled in this slot
Hardware revision 1.1 Board revision N0
Serial number 30246568 Part number 800-02495-01
FRU Part Number VIC-2FXO=
Test history 0x0 RMA number 00-00-00
Connector type Wan Module
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 0D 01 01 01 CD 86 A8 50 09 BF 01 00 00 00 00
0x30: B8 00 00 00 03 05 21 01 FF FF FF FF FF FF FF FF
This occurs with either IOS image. Any tips or thoughts on why this occuring? Thank you in advance for any help.
Solved! Go to Solution.
09-09-2012 10:41 PM
As the router is telling you, that old module is not supported on the NM.
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a00800ae37f.shtml
09-09-2012 10:41 PM
09-10-2012 06:43 AM
Ah, yes, the subtle difference between VIC2-2FXO and VIC-2FXO. I have the wrong hardware =\
Thank you the clarification!
09-10-2012 07:08 AM
Thank you for the nice rating and good luck!
