3rd Party Directory for 8800 Phones? Directory for Sub-Tenants
Randall White
Level 3
Level 3
I am looking for a 3rd party directory server. I have sub-tenants that are on a different AD domain, and they can't use the directory button on the phone.
There is a MultiDirectory ASP file in the IP Phone Services SDK, but I understand it doesn't work with 7800/8800 SIP phones. Google search hasn't turned up anything else.
So what are you folks doing in this situation?
Thanks, Randy
Jaime Valencia
Plenty of directory options if you search marketplace/solution partner program.
java
if this helps, please rate
There are a few, but only as part of larger (and more expensive) suites. I didn't see any stand alone products.
Dr Alban
Hi Randy, I developed my own standalone XML directory system for 7800 and SPA phones (chances are it would also work for 8800 phones if they use the same format) hosted on the internet and with a web interface for management. It's still in beta and not open to the general public but I could give you a preview if you'd like?
Thanks, but I am looking for an on-premise solution.
