6800/7800/8800 3PCC and SRTP
Aaron Mount
The data sheets all say the 6800 / 7800 / 8800 series phones support SRTP, but I cannot find a way to enable it on the 3PCC models... not in the UI nor via XML. Am I missing something?
The administration guide is the most specific thing I've found; the following parameters are mentioned:
TR.069 ParameterXML Parameter
Device.Services.VoiceService.{i}.VoiceProfile.{i}.RTP.SRTP.
Device.Services.VoiceService.{i}.VoiceProfile.{i}.RTP.SRTP.EnableN/A
This seems to suggest XML configuration is not possible. Is that truly the case? And if it's not possible today, when might that functionality be added?
bijpraka
On UI you can find the parameters under:
Voice->User->Secure Call Setting -> Set this to Yes.
This will ensure secure calls are accepted and not rejected.
And for ensuring all calls are secure set this:
Voice->Ext n->Call Feature Settings ->Secure Call Option -> Set this to Required.
Both parameters have corresponding XML tags as well.
Thanks.
bijpraka
Thanks.
