10-02-2013 09:05 AM - edited 03-16-2019 07:39 PM
we have CM 9.1.1A and 6945 phones. once in a while the customer complains that when they pick up phone and dial, they hear dial tone, then silence until someone picks up call - no ringback. this happens on all calls, extension to extension, etc.
sometimes, a phone will do this continuously until we rest power to phone, then it is ok. other times the phone just begins working ok on its own.
any ideas as to what could be the cause? already upgraded phone to latest firmare ES2, still no go.
phil
Solved! Go to Solution.
11-04-2013 12:39 PM
I have the same problem our phones are on ES2 and still having this problem. It is intermittent but very annoying.
11-04-2013 12:39 PM
01-21-2015 01:47 AM
Dears,
I have the same issue on 6945 phones callers cant hear a ringback tone.I have uploaded the latest firmware SCCP6945.9-4-1-3 but the fix is in SCCP6945.9-4-1-r3936 which is not available on cisco website
How i can get it
01-21-2015 05:40 AM
01-21-2015 05:42 AM
Do you have the original cop.sgn file?
01-21-2015 06:13 AM
No. This is all I have. This was sent to me by the tech I was working with at Cisco.
01-21-2015 06:47 AM
Dear Bradley,
How i can upload these files in CUCM 9.1.2
01-21-2015 07:15 AM
Go to OS Administration and TFTP file management and upload all 5 files to the root and then change your firmware loads in device defaults or on the individual phones to reflect the new load id
01-22-2015 08:51 PM
thanks for the files and instructions bradley,mloraditch.
04-02-2014 11:23 PM
I want to update this problem because I have the same. Is ther some one solved it ?
04-03-2014 05:40 AM
I worked with cisco and they sent me an update for the phones. I am not sure if it was released yet or not. My phones now have SCCP6945.9-4-1-r3936.
04-03-2014 09:26 AM
Hi, thank's for your answer.
Is it possible to you to send me this firmware by email ?
pbardaji@axians.com
Best reagrds
Pierre
12-12-2014 07:30 AM
Bradley,
I know this was months ago but do you have a bug id? or alternatively is this firmware newer than 9-4-1-3 that is on CCO?
Thanks!
12-15-2014 12:54 PM
Not sure it is newer but I know that it fixed my problem but when I was working on another phone and I had 9-4-1-3 it started having the problem again.
04-03-2014 08:17 AM
I'd take a look at a packet capture as well as console logs and open a TAC case.
