Showing results forĀ
Search instead forĀ
Did you mean:Ā
78XX 3PCC disable activation code
Genadi
I am not going to use activation code on phone. I just want it to register on asterisk server.
How can i remove "Enter activation code" message on phone display ?
Jaime Valencia
Once the device is properly configured and registers to your PBX that will no longer show.
java
if this helps, please rate
Jaime Valencia
java
Access the web GUI of the phone and complete the required configuration  with asterisk and the phone will never ask for activation code as JAVA mentioned.
Response Signature
