78XX, CUCM 8.6 and phone information
jmecklenburg
Level 2
Level 2
I have a CUCM 8.6 with the device package "cmterm-devicepack8.6.2.26169-1.cop.sgn" installed for phones 78XX and the phones work fine, the phone register and update the locale to es_CO. But I can't see the phone information under application menu.
Then I try downgrade the firmware to the version sip78xx.10-3-1-12 to sip78xx.11-0-1-11 and the process ended without problems, but the phone still don't showing the phone information under application menu.
According with the release note http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7800-series/11-0-1/releasenotes/pa2d_b_cisco-ip-phone-7800-series.html I don't see any caveat related with my problem.
In the generic user guide this option is available
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7800-series/english/user-guide/PA2D_BK_I89BE38F_00_ip_phone-7800-series-user-guide/PA2D_BK_I89BE38F_00_ip_phone-7800-series-user-guide_chapter_00.html
I don't know what happen. I hope can help me with this.
fixie rider
jmecklenburg
Level 2
Level 2
Also I tried configuring the phone with english locale but still don't see the phone information
Any idea?
fixie rider
Can you attach the screenshot of what exactly you are seeing?
Adarsh Chauhan
Please rate and mark correct if helpful
Adarsh Chauhan
Hi, thanks for your answer, attach the screenshot.
In the application menu I only see this:
1.- Call history
2.- Preference
3.- Accessories
4.- Bloqueo (Extension Mobility)
https://dl.dropboxusercontent.com/u/41586300/7821-app-01.png
https://dl.dropboxusercontent.com/u/41586300/7821-app-02.png
Tanks
fixie rider
I will check this today in office however in the meanwhile can you check on the 7821 phone
configuration page if you have set Settings Access to Restricted or Disabled ?
Also check the Common Phone Profile for this phone where you will find the same setting.
Adarsh Chauhan
Adarsh Chauhan
