04-15-2014 05:30 PM - edited 03-16-2019 10:28 PM
We have few 7921/7925 SCCP phones deployed on CUCM 9.1.1.20000-5. The Active Load shows Unknown for 7921/7925. We can see Active Load info for other handsets. It would be handy if we could see firmware load info under Active Load for 7921/7925.
Current firmware version for 7921/7925 are: CP7921G-1.4.5SR1.3.loads and CP7925G-1.4.5SR1.3.loads.
Any idea why active load shows Unknown for 7921/7925?
Cheers
Fei
Solved! Go to Solution.
04-15-2014 08:05 PM
Hi Fei,
check the link if it helps.
https://supportforums.cisco.com/discussion/10881226/active-load-id
regds,
aman
04-16-2014 10:50 AM
Hi Fei,
Just to add a note to the good tips from my buddy Aman (+5!)
I think the bug listed by Brad in this note would be applicable here
https://supportforums.cisco.com/discussion/11430991/active-load-id
Cheers!
Rob
04-15-2014 08:05 PM
Hi Fei,
regds,
aman
04-15-2014 08:13 PM
Hi Aman
I read this discussion earlier before i posted.I dont think that fits to my scenarios as we are on CUCM 9.1 and 7921/7925 are all registered. Still appreciated your response.
Cheers
04-15-2014 08:39 PM
Hi Fei,
Just a thought,do you have latest Device pack loaded on CUCM? for 792X?
regds,
aman
04-15-2014 09:02 PM
Hi Aman
As i mentioned in discussion, all 792x handsets are loading latest firmware 1.4.5SR1.3.
Fei
04-16-2014 10:50 AM
Hi Fei,
Cheers!
Rob
04-16-2014 09:08 PM
Hi Rob
Thx for tips but we client want confirmation from Vendor. We decide to engage Cisco to find out more.
Cheers
Fei
04-17-2014 10:00 AM
Hi Rob,
thanks for sharing the bug[+5].
Hi Fei,please do share the findings of cisco.
regds,
aman
04-29-2014 07:27 PM
Hi Aman
Will do.
06-12-2014 07:13 PM
hi Rob/Aman
Cisco advised this is a known cosmetic issue for many 69xx and 79xx phones under CSCtc10818. But to determine whether phone is running SCCP 17, packet capture is required on CUCM but client decide to not to chase further. That's how we ends.
Thanks again.
Fei
06-12-2014 07:54 PM
thanks for update.
regds,
aman
