12-05-2015 01:00 AM - edited 03-17-2019 05:07 AM
HI every one,
I have a 7942 all light on and showing blank screen
I checked DHCP server , phone didn't get any IP
Please guide me
Thankx & Regards
Sayed
12-05-2015 03:05 AM
Hi Sayed,
Plz make sure that the phone is connected to a good known working port with dhcp and option 150 configured and perform a factory reset. You may watch the following video for factory reset procedure.
Manish
- Do rate helpful posts -
12-05-2015 06:24 PM
Are this phone connected to Cisco Switch? Is switch port configuration is correct? Is phone getting the correct vlan , are you seeing broadcast request
can you please share show run from switch ? and where is DHCP server is configured? share the dhcp config too.
do show cdp neig and show cdp neig detail
Br,
Nadeem
12-06-2015 12:23 AM
thanks for your helping
all configuration of switch and DHCP working good I try another phone on sam port of switch
the problem in the cisco phone it self ,phone not booting , all lights on and balnk screen
