7961G GE Headset Issue
Zafar Ullah
Headset conversations coming through in parallel on the speaker button of the 7961 phones.Any one got any Idea Please share if you have come across this issue
Jonathan Schulenberg
This was how the firmware was written until recently. You can upgrade the firmware to a current release and either it will stop; or, you will get an option on the model-specific settings of the device configuration page to disable that behavior.
Please remember to rate helpful responses and identify helpful or correct answers.
The phones are 7961G GE  and the firmware SCCP41.9-1-1SR1S.Which is the upgraded version
This is issue is also happening with Model 7965.
Hi Jonathan
Thanks for your help.It has fixed the issue for 7965 but I have come across with cisco Bug Tool
CSCsz35375.which has mentioned that 7961G GE has build in for this.Once again thanks for your help
It is much appreciated
Zafar
