7962G Phone Problem Time/Hour
Hello Firends,
I´m working with CUCM, version 6.1.4.1190-3.   7962G file phone is SCCP42.8-4-4S.
I conected 7962G phone at CUCM, but the time (hour) isn´t the same time from CUCM. The diference is one hour between them. What can i do?
Help me please...
5 Replies 5
Chris Deren
Does the device pool you assigned to the phone reference the proper date/time group?
Chris
Yes Chris, 7962G phone is the same date/time group than other phones...
Other phones work normally....
Is phone running the default firmware file? Have you tried factory reset on the phone?
Chris
slashdots
If all 7962 have the same problem, and other models work great, this reminds me on this bug:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtg50448
If possible I would open a TAC
Chirs,
Phone has default firmware. I reseted it, but problem goes on...
