I have a customer who has the following setup:SIP Provider => MPLS => CUBE (SIP) => CCM (SIP) - cube set for passthu using NSE CCM (MGCP) => VG224 - set for passthu using NSE CCM (SIP) => ...
Hi folks,I'm still not able to place a call from my pstn site to my cme site.The calling number is 999 and the called number is 32143001I am able to call from cme to the pstn site (999)But backwards not.I've checked my voice translation rules and dia...
If a CUE Default prompt is accidentally recorded over or erased how may it be recovered or downloaded versus a full factory default reset of the CUE?
Hi All, A small query about something which i seem to be missing on the CIPC phone that i have been working on in my organization.I need to take make some test calls and have some sniffers/ packet captures through the CIPC phone, but all i can see ...
Hi,MGCP gatewayRoute group distribution: Top downIn this type, calls will go to top to down , i.e.., covering all 30 channels in E1 line and passing to another E1 line, is it correct?If yes, how to change the behaviour to pass a first call to 1E1 lin...
HiI am using extension mobility it is working fine ,but I when I earch the phones by directory numbers i can not fine the device profile directory number.Is there a way to map the directory number with the mac address or any other way to solve this i...
Hello,I have a router running CME 8.5 and CUE 7.1. CUE is running on an AIM-CUE module. The licensing dashboard is reporting the 40 days left on the demo license. I think this is for CUE as I am under the impression that the CME licensing is inclu...
Hi There,I am installing CUCM 8.0 on VM ware 9.0, I am seeing this errro once i have given the image from the same laptop.Could not find kernal image : linuxboot:Hardware details which I have given in VMWARE:HDD Size - 40GMemory - 1 GThanks & regards...
Hi all,I have a third party solution for recording calls, (SIP Trunking and BIB enabled in phones) but when I try recording a device type 8945, only audio is send to Recording Server.Somebody knows how is H.264 is sent to Recording Server or how its ...
Hi,I can change the Server IP Address manually by following the below steps:CUCM Web Console->System->Server->Change CUCM IP AddressI need to do the same thing using AXL API but I could not find the AXL API for the above task.Could anybody help me to...
Hi I config CME on a C2851 router ,and all cisco Ip phone\SIP phone are work fine in the local lan. The outside user also can use the phone over VPN. And now they donot want to dial vpn before use ipphone. Is anybody know how to config it? in...
Hi,I want to mitigate to identity spoofing when someone uses softphone with the same MAC Address of hard phone. what's the simple security method to block this attack. RegardsDriss
Hi,I have two CUCM clusters and trunk has been created between them.Now when I call from one IP phone which is registered on CUCM of 1st cluster to the second IP phone which is registered on CUCM of 2nd cluster, there is only one-way audio.I have rec...
Cisco CME 8.6 have SIP trunks connected to provider server as IP Trusted list (not as register SIP trunks) and have internal SIP devices (Apple iphone and ipad) which require registration to this cme as local extensions. Office Telepony connection to...
Hi Everyone,I have several question regarding CUCM IC GroupsQuestions:1. I have 3 servers in a cluster that can support 7500 user each, sometimes I see phones registering with the Secondary server while the primary only has 3000 phones registered wit...
Subject | Author | Posted |
06-19-2025 08:23 PM | ||
06-17-2025 07:43 AM | ||
06-17-2025 06:11 AM | ||
06-09-2025 09:11 AM | ||
06-05-2025 02:29 PM |
User | Count |
2 | |
2 | |
1 | |
1 | |
1 |
