7965--Phone--Services
abdulkarim041
Level 2
Level 2
I have Cisco 7965 phone. I am facing the error on it as attached. How I can get rid of it?
BR
Abdul Karim
On the phone config page > External Data Locations Information > Idle -- do you have any URL here? If yes, try deleting that and Idle Timer. Then save config, apply config and reset the phone. Default will be taken from Enterprise Parameters > Phone URL Parameters > URL Idle (leave black if not required)
Manish Gogna
Hi Abdul,
Please check the following post with similar query
https://supportforums.cisco.com/discussion/12292751/ip-communicator-service-issue
Manish
Hi Gogna,
I have applied all solutions mentioned in your provided link. But I could not get success. Issu.e is still there.
BR
Abdul Karim
