7970 sip firmware unziping error
tritron777
I had downloaded lates sip firmware for 7970 and when I try to unzip file I get error Invalid compresses data to extract. Header not found also is being diplayed. Where I can find sip firmware that can be unziped and placed in tftp server.
5 Replies 5
Aaron Harrison
Usually there is a ZIP file, an exe, and a cop file. Which did you download?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
It is zip file.
Look like the zip file is damaged. I can't tell you where you can the find the firmware because it should be buy from Cisco but you can use google to find it .
Please rate all useful posts
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
Great the firmware was downloaded from cisco. I had downloaded firmware for 7911 7906 without issue.So does this mean cisco gives us faulty firmware ?
Try downloading the file again maybe was corrupt during the process. You can use the checksum to verify the file health.
