10-04-2019 07:20 AM
Trying to connect a 8800 KEM to a 8865 phone. Have looked at several forums and threads, tried all the settings. Still get the same message on the phone when I connect the 8800 'the phone is not set up for the expansion module'.
In CUCM have tried the One Column Display for KEM, the Power Negotiation, Phone Button Template, different switches, nothing seems to matter. The phone is recognizing the KEM, or other USB powered devices.
Help?
Solved! Go to Solution.
10-07-2019 11:16 AM
The A-KEM is the Audio-KEM and the V-KEM is the Video-KEM. You can only use the V-KEM on a video phone and an A-KEM on an audio phone (i.e. 8865 vs 8851). For the BEKEM that you have, that is EOL. The V and A KEM replaced it. Check out the EOL page:
10-04-2019 07:37 AM
This may be a silly question but do you have a KEM specified under Expansion Module Information? Also, what is the phone button template configured for? Is it something like 1L 4S 36KEM (1 line, 4 speed dials = 5 lines on the 8865 and 36 on the KEM)?
10-04-2019 07:51 AM
The Expansion Module Information shows as: CP-8800-Video 28 Button Key Expansion Module.
I have 2 button templates I have tried.
1. Name: 'Standard 8865 SIP', shows 10 buttons, lines 1 and 2 as Line and the remainder speed dial.
2. Name: 'Standard 8865 SIP + KEM', 118 buttons, lines 1 and 2 as Line, buttons 3-10 as speed dial, the remainders as none.
01-16-2024 04:50 AM
10-04-2019 07:45 AM
10-04-2019 08:15 AM
Active load shows: sip8845-65.12-5-1SR1-4 on the 8865 phone.
I have both a 8800 28, and a 8800 36. The 36 is now powering on after adding buttons to the phone button template. The 28 will not respond to any changes. I will see if I can find a power supply, but I would assume the 28 would work before the 36 would if that is the case. Will let you know.
10-04-2019 08:34 AM
No change on the 28 button KEM after adding external power supply.
10-04-2019 07:47 AM
Do you have 28-button or 36-button KEM module? Make sure to select correct KEM module under phone configuration.
10-04-2019 08:16 AM
I have both and am selecting them as I connect them. The 28 will not power on at all, the 36 is now powering on after modifying the phone button template.
10-04-2019 08:28 AM
Try disabling Power Negotiation on phone configuration page for 28-button module.
10-04-2019 08:33 AM
Power Negotiation does not change anything. With or without an external power supply.
10-04-2019 11:20 AM
So, it appears I have two separate issues.
1. the 36 Button KEM had the wrong button template. Changing that made it work.
2. the 28 button (cp-8800-a-kem) will not work under any button template, any product specific line changes or with additional power. My CUCM option under module 1 shows: CP-8800-Video 28 button key expansion module
So, other than the forums so far I have seen. Line mode does not help, Power Negotiation does not help, One Column Display for KEM does not help, or a new button template. Any suggestions? I'll try it.
10-04-2019 12:12 PM - edited 10-04-2019 12:14 PM
Can you try upgrading the phone to latest version 12.6(1).
10-04-2019 01:54 PM - edited 10-04-2019 02:20 PM
UPDATE: firmware updated and installed. Same difference on 8800 28 button. Still when connecting comes up with the same message.
10-07-2019 05:16 AM
In this case, I would recommend opening Cisco TAC case.
