8821 WLAN Phone - Third Party PBX
at
ist it possible to connect the Cisco WLAN Phone 8821 to a third-party pbx (sip-provider)  - CUCM is not involved ?
I know some 88xx are delivered with third-party call control firmware.
thank you regards
Alex
7 Replies 7
skilambi
3PCC load is not there for 8821, 8845/65, 8831 and 7832 today
Srini
Hi - thanks for your answer - do you know at what timerange  such 3PCC (spec. 8821) will be available ?
regards
Alex
Last month no plans were shared so I am not sure if it’s high on the roadmap on any near time updates on this. I wouldn’t hope for anything anytime soon.
Srini Kilambi
Yes, if anything is added to the 8821 then Spark is first I believe.
Any Update on the 3rd party Support?
To my knowledge, there is no 8821 3PCC model yet
Hope this Helps
Cheers
RKM!
  please take a look at the following: 8821 3PCC.
Hope this helps,
Marcelo Morais
