8865 expansion module locale
mkhriesa
cucm 11.0 , is there anyway just  to change the expansion module language and keep the phone English?
HARIS_HUSSAIN
Try to update user and network local on the phones' common device config OR Directly on Phone Page o English and Reset Phone.
If English option is not there then you may need to install the Locale in CUCM.
Haris
Please rate and mark correct.
hi,
I can choose English locale for the phone from phone page config , but my question, can I use English locale for phone and Arabic locale for module? both loacale installed on cucm but I just can change both for same locale , any idea?
This is not possible since the extension "takes" the settings from the main device and the only thing you can change is the "Phone Button Template"
G
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
This is not possible. Phone and Module will take same locale
