911 Busy
PerrNetAdmin
Our setup was done by a vendor and worked well. All of the sudden 911 calling stopped working. We get an immediate busy signal. I talked with our telco provider and they tell me they can't replicate it so it must be our equipment. I am looking for troubleshooting ideas. So far I have checked call routing patterns, CER, CDR, RTM, and the gateway. Everything I am looking at seems to show we are calling 911. CER is sending all the proper alerts and the call appears to be hitting the proper dial peer on the gateway.
I attached a picture of our route pattern.
Here is RTM text from a test call:
2019/11/18 11:31:29.744|CC|SETUP|41688539|41688540|2514|911|911
2019/11/18 11:31:29.748|CC|OFFERED|41688539|41688540|2514|911|911|SEPB8621F6DD5A5|CER-911
2019/11/18 11:31:29.850|CC|SETUP|41688539|41688542|4198728840|911|911
2019/11/18 11:31:29.854|CC|OFFERED|41688539|41688542|4198728840|911|911|SEPB8621F6DD5A5|10.50.58.5
2019/11/18 11:31:29.856|CC|RELEASE|41688540|0|0
2019/11/18 11:31:33.615|SIPL|41688536|TCP|IN|10.50.57.10|5060|SEP000832C7786C|10.50.59.100|49883|2,100,14,5020.64188^10.50.59.100^*|17565534|cfc9b000-dd21c749-451fc-a392e0a@10.50.57.10|BYE
2019/11/18 11:31:33.617|SIPL|41688535|TCP|OUT|10.50.57.10|5060|SEP000832C79F05|10.50.59.114|52384|2,100,14,5020.64188^10.50.59.100^*|17565535|000832c7-9f05ee24-5efc22c4-6e8048e2@10.50.59.114|BYE
2019/11/18 11:31:33.618|SIPL|41688536|TCP|OUT|10.50.57.10|5060|SEP000832C7786C|10.50.59.100|49883|2,100,14,5020.64188^10.50.59.100^*|17565536|cfc9b000-dd21c749-451fc-a392e0a@10.50.57.10|200 OK
2019/11/18 11:31:33.722|SIPL|41688535|TCP|IN|10.50.57.10|5060|SEP000832C79F05|10.50.59.114|52384|2,100,14,95936.2577^10.50.59.114^*|17565539|000832c7-9f05ee24-5efc22c4-6e8048e2@10.50.59.114|200 OK
Here are our dial peers:
dial-peer voice 1001 voip
preference 2
destination-pattern 419.......
modem passthrough nse codec g711ulaw
session target ipv4:10.50.58.10
incoming called-number .
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric h245-signal rtp-nte
fax-relay ecm disable
fax rate disable
no vad
dial-peer voice 10 pots
preference 1
destination-pattern 8[2-9].........
direct-inward-dial
port 0/0/0:23
forward-digits 10
dial-peer voice 20 pots
preference 1
destination-pattern 81[2-9].........
direct-inward-dial
port 0/0/0:23
forward-digits 11
dial-peer voice 30 pots
preference 1
destination-pattern 8011T
direct-inward-dial
port 0/0/0:23
prefix 011
dial-peer voice 40 pots
preference 1
destination-pattern 911
port 0/0/0:23
forward-digits 3
dial-peer voice 50 pots
preference 1
destination-pattern 8911
port 0/0/0:23
forward-digits 3
dial-peer voice 1000 voip
preference 1
session target ipv4:10.50.57.10
voice-class codec 1
voice-class h323 1
fax rate disable
no vad
Here is a debug on the dialpeers:
000414: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpAssociateIncomingPeerCore:
Calling Number=4198728840, Called Number=911, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
000415: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=911
000416: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpMatchPeertype:
Is Incoming=TRUE, Number Expansion=FALSE
000417: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpMatchCore:
Dial String=911, Expanded String=911, Calling Number=
Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
000418: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=1001 Is Matched
000419: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=10 Is Matched
000420: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=20 Is Matched
000421: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=30 Is Matched
000422: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=1000 Is Matched
000423: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpMatchPeertype:exit@7211
000424: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1001
000425: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
000426: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpAssociateIncomingPeerSPI:exit@7793
000427: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpMatchPeersCore:
Calling Number=, Called Number=911, Peer Info Type=DIALPEER_INFO_SPEECH
000428: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=911
000429: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpMatchCore:
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
000430: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=40 Is Matched
000431: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
000432: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpMatchSafModulePlugin:
dialstring=911, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
000433: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=40
000434: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpMatchPeersCore:
000435: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpMatchPeersCore:
000436: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpMatchCore:
000437: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/MatchNextPeer:
000438: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpMatchPeersCore:
000439: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpMatchSafModulePlugin:
000440: Nov 18 11:16:32.054: //-1/00CE4E368245/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=40
000441: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=911, Called Number=911, Peer Info Type=DIALPEER_INFO_SPEECH
000442: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000443: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=911, Expanded String=911, Calling Number=911T
000444: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
000445: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000446: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
000447: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=40
000448: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=911, Called Number=, Voice-Interface=0x0,
000449: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=911
000450: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
000451: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=911T
000452: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
000453: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@7211
000454: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=911
000455: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
000456: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
000457: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=40 Is Matched
000458: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@7211
000459: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=NO_MATCH(-1) After All Match Rules Attempt
000460: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
000461: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@7842
000462: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
000463: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
000464: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
000465: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
000466: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
000467: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@7211
000468: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
000469: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
000470: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
000471: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
000472: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@7211
000473: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
000474: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
000475: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@7842
000476: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000477: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000478: Nov 18 11:16:32.054: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
000479: Nov 18 11:16:32.058: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
000480: Nov 18 11:16:32.058: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000481: Nov 18 11:16:32.058: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
000482: Nov 18 11:16:32.058: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=40
000483: Nov 18 11:16:32.058: //-1/00CE4E368245/DPM/dpMatchPeersCore:
000484: Nov 18 11:16:32.058: //-1/00CE4E368245/DPM/dpMatchPeersCore:
000485: Nov 18 11:16:32.058: //-1/00CE4E368245/DPM/dpMatchCore:
000486: Nov 18 11:16:32.058: //-1/00CE4E368245/DPM/MatchNextPeer:
000487: Nov 18 11:16:32.058: //-1/00CE4E368245/DPM/dpMatchPeersCore:
000488: Nov 18 11:16:32.058: //-1/00CE4E368245/DPM/dpMatchSafModulePlugin:
dialstring=911, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
000489: Nov 18 11:16:32.058: //-1/00CE4E368245/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=40
I have been trying to pic through this, but I am not too sure what I am looking for. To me it appears as though the call is getting routed to CER and then sent out the gateway as 911. All regular calling is working fine though. Thank you to anyone who can help provide insight.
Tanner Jackson
I'm guessing your CER is prefixing 7851 to the 911 dial string on the way back from CER then your Route Group must be discarding the predot as it gets sent back to your gateway. Can you attach a screenshot of your TECH-ONLY route group?
Can you also run a 'debug isdn q931', place a call and attach the results?
Tanner: I agree, the debug isdn q931 is going to be really helpful. Also, a debug voip ccapi inout would be too.
It kind of smells like one of those instances where the gateway is sending redirecting IE delivery on outbound, and CER does use that field, but most telcos will reject a 911 call that appears to be forwarded/redirected to them, as opposed to called directly.
OP: Can you also post your H323 Gateway page setting CUCM for this gateway as it pertains to the outbound redirecting deliver setting?
