9971 video not working
tato386
Level 6
Level 6
I have three 9971 phones all registered to the same CUCM.  They all have the same firmware and as far as I can see all three have the same settings include video enabled, etc.  However, one of the phones cannot place video calls. The camera is working because I can see myself when I test it but it doesn't work when I call the other 9971s.  What can I look for here?
Diego
tato386
Level 6
Level 6
I removed the phone from CUCM, did factory reset and after adding back in it is working.
Thanks all,
Diego
7 Replies 7
Andrew Skelly
Level 7
Level 7
I have run in to this issue before and the fix was to remove the camera and reseat it.
Please rate helpful posts by clicking the thumbs up!
Worth a shot.  I'll try it and let you know.
Well I removed the camera from the non-working phone and installed on a working phone and it worked. Moved back to "bad" phone and still no go. Factory reset of bad phone did not work either. I am going to delete the phone and recreate using a working phone to see if that helps.
Diego
Dennis Mink
are these phones in the same devicepool and region that has video bandwidth allowed between phones?
Please remember to rate useful posts, by clicking on the stars below.
The problem phone is in a different pool but I moved it into the same pool with the working phones and it did not make a difference.  Thx
in that case dont waste too much time on it and RMA it, so it can be replaced under maintenance
tato386
Level 6
Level 6
Thanks all,
Diego
