About GK Log
CN_donke.xu
Hello Friends
I want to use GK Connect two CCM,and when i finish all config i  can see this log in my GK,is there something error in this log ?i can't make a internal call now.
GATEWAY TYPE PREFIX TABLE
Prefix: 701*
Zone VLA10MACGK1 master gateway list:
10.112.127.233:51250 trunk01_7
10.112.127.234:33022 trunk01_1
Prefix: 31#711*
10.119.200.12:49753 VLA10GK1POD_2
10.119.200.13:41220 VLA10GK1POD_3
.Oct 29 12:47:15 VVO: //xxxxxxxxxxxx/xxxxxxxxxxxx/GK/gk_process: QUEUE_EVENT (minor 0) wakeup
.Oct 29 12:47:15 VVO: //xxxxxxxxxxxx/xxxxxxxxxxxx/GK/gk_rassrv_arq: arqp=0x24718060,crv=0x29, answerCall=0
.Oct 29 12:47:15 VVO: //xxxxxxxxxxxx/xxxxxxxxxxxx/GK/gk_rassrv_sep_arq: ARQ Didn't use GK_AAA_PROC
.Oct 29 12:47:15 VVO: //802E8F572900/802E8F572900/GK/gk_dns_query: No Name servers
.Oct 29 12:47:15 VVO: //802E8F572900/802E8F572900/GK/rassrv_get_addrinfo: (31#7119927) Matched tech-prefix 31#711
.Oct 29 12:47:15 VVO: //802E8F572900/802E8F572900/GK/rassrv_get_addrinfo: (31#7119927) unresolved zone prefix, using source zone VLA10MACGK1
.Oct 29 12:47:15 VVO: //xxxxxxxxxxxx/xxxxxxxxxxxx/GK/gk_rassrv_get_ingress_network: returning default ingress network = 1
.Oct 29 12:47:15 VVO: //802E8F572900/802E8F572900/GK/rassrv_arq_select_viazone: about to check the source side, src_zonep=0x20284848
.Oct 29 12:47:15 VVO: //802E8F572900/802E8F572900/GK/rassrv_arq_select_viazone: matched zone is VLA10MACGK1, and z_invianamelen=0
.Oct 29 12:47:15 VVO: //802E8F572900/802E8F572900/GK/rassrv_arq_select_viazone: about to check the destination side, dst_zonep=0x20284848
.Oct 29 12:47:15 VVO: //802E8F572900/802E8F572900/GK/rassrv_arq_select_viazone: matched zone is VLA10MACGK1, and z_outvianamelen=0
.Oct 29 12:47:16 VVO: //xxxxxxxxxxxx/xxxxxxxxxxxx/GK/gk_process: got a TIMER event
.Oct 29 12:47:16 VVO: //xxxxxxxxxxxx/xxxxxxxxxxxx/GK/gk_handle_timers
.Oct 29 12:47:16 VVO: //xxxxxxxxxxxx/xxxxxxxxxxxx/GK/gk_handle_timers: managed timer expired 0xD373EB8
.Oct 29 12:47:25 VVO: //xxxxxxxxxxxx/xxxxxxxxxxxx/GK/gk_process: QUEUE_EVENT (minor 0) wakeup
Best Regards
Donke xu
Nadeem Ahmed
can you please show run from GK along with follow debugs. enable below debugs and make a test call.
Debug gatekeeper main 10
debug gatekeeper call 10
debug ras
debug h225 asn1
debug h245 asn1
also share below command output
show gatekeeper endpoint
show gatekeeper gw
show gatekeeper zone status
show gateway
Br,
Nadeem
Br, Nadeem Please rate all useful post.
Nadeem Ahmed
debug ras
debug h225 asn1
debug h245 asn1
show gatekeeper gw
show gateway
Br,
Nadeem
