About Secondary Dial Tone on CME
markjiang
How can voice gateway provide outside dial tone to 3951 just like what cucm do?
P.S.
I have configed dial plan for 3951.
Thanks & Regards
Michelle Jardim
This SIP phone on CME does not support secondary dialtone. Only SCCP phone does with the configuration below:
telephony-service
     secondary-dial digit-string
Hope this can help you.
Michelle Jardim
5 Replies 5
iptuser55
Level 6
Level 6
in the telephony service - I think there is a commend "secondary dial tone" which you add
The 3951 is a SIP phone and as such, not influenced by any command under telephony-service.
This said, I don't know what can be causing the problem.
 From Cisco Unified CME Release 11.6 onwards, secondary dial tone is supported on both SIP phones and SCCP phones.
Example for Configuring Secondary Dial Tone on SIP Phones
A secondary dial tone is played on the phone when comma (',') is found in the pattern. In this example, secondary dial tone is played after the digit 50.
voice register dialplan 1
 type 7940-7960-others
 pattern 1 50,
voice register pool 1
 busy-trigger-per-button 2
 id mac 0C11.6780.52A3
 type 7841
number 1 dn 1
 dialplan 1
 dtmf-relay rtp-nte
 username cisco1 password cisco
 codec g711ulaw
 no vad
 provision-tag 1
Michelle Jardim
telephony-service
Michelle Jardim
Hi,Michelle,
I have tested the secondary dial tone command under telephony service.
However,it doesn't effect SIP phone.
