08-26-2012 10:53 PM - edited 03-16-2019 12:53 PM
Hi All,
I installation 9971 SIP Phone on CME.
if I config:
telephony-service
secondary-dialtone 0
this is only support SCCP Phone.
How can configuration SIP phone secondary dial tone on CME?
Thanks.
Solved! Go to Solution.
08-26-2012 11:15 PM
Many, many features are not supported on SIP phones.
For this reason, is much better to use only SCCP phones.
08-26-2012 11:15 PM
08-27-2012 01:08 AM
Oops. Cisco 9971 IP Phone only support SIP........
08-27-2012 08:55 AM
Correct. Otherwise I would have said "Phones in SCCP mode", or "switch to SCCP firmware".
Thank you for the nice rating and good luck!
06-23-2017 07:45 PM
From Cisco Unified CME Release 11.6 onwards, secondary dial tone is supported on both SIP phones and SCCP phones.
A secondary dial tone is played on the phone when comma (',') is found in the pattern. In this example, secondary dial tone is played after the digit 50.
voice register dialplan 1 type 7940-7960-others pattern 1 50, voice register pool 1 busy-trigger-per-button 2 id mac 0C11.6780.52A3 type 7841 number 1 dn 1 dialplan 1 dtmf-relay rtp-nte username cisco1 password cisco codec g711ulaw no vad provision-tag 1
