ā03-15-2012 06:08 AM - edited ā03-16-2019 10:08 AM
I have Cisco Unified Communication Manager Cluster( version: 8.6.2.2000-2).
I will add a new subscriber to existing cluster.
I have : a new 8.5. instaliation dvd , 8.6.2.2000-2 upgrade dvd.
is it possible to add the new subscriber to cluster. or is it posibble firstly install 8.5 as subs.
later?
first install cop file and later 8.6.6 upgrade dvd. is there any path for add a new subs in cluster. Because ı havent 8.6.2.2000-2 installiation dvd.
Regards.
ā03-15-2012 06:12 AM
HI
The subscriber should have same CUCM release in installation DVD.
Rgeards
Ronak patel
ā03-15-2012 06:17 AM
I havent same release with cucm cluster. When We add a new subscriber it is posible to upgrade (for reach to cluster version I thinks. But from 8.5. to 8.6 you should install cop file before upgrading 8.6). My aim is how to doing this issue.
And Ronak is there any official decument about your saing.
Regards.
ā03-15-2012 06:15 AM
Boot from the 8.5 installation DVD. When it says 'do you want to install a patch' say 'yes'.
Then it will continue... at some point it will ask for an upgrade patch, select 'local', insert the 8.6.2 DVD and hit OK. It will then install 8.6.2 version instead and you can add it direct to the cluster.
Aaron
ā03-15-2012 06:19 AM
. When We add a new subscriber it is posible to upgrade (for reach to cluster version I thinks. But from 8.5. to 8.6 you should install cop file before upgrading 8.6). My aim is how to doing this issue. (aaronharrison)
ā03-15-2012 06:37 AM
It is not documneted. But I have seen TAC case where it has created problem.
Best solution would be to ask for Bootable media form your Cisco Sales team.
Ronak Patel
ā05-29-2012 01:43 PM
Did you manage to install the new subscriber?
I am trying to do something similar (but with an 8.0(3) bootable DVD AND UPGRADRING TO 8.6(2a)su1) and when I try the process suggested by Aaron I get a message "Unable to install patches, disk xxxx directory /"
I know the disk is ok as I have used it to upgrade other servers in the cluster from 8.0(3) to 8.6(2a)su1.
Can anyone confirm that what I am trying to do should work?
ā05-29-2012 01:53 PM
Hi James,
Please read this document before you upgrade..
https://supportforums.cisco.com/docs/DOC-16898
Pls rate useful posts..
ā05-29-2012 02:39 PM
Thank you for the response but unfortunately the document you linked to does not cover the issue that I (and the OP) are faced with.
Can anyone else help?
ā05-29-2012 11:02 PM
Hi James,
If you want to upgrade from the prior the 8.5.1 to 8.6.x you have to firsty install applicable COP file then upgrade.
ā05-29-2012 11:05 PM
By the way this document will cover your issue I think as "aokanlawon"
