Add Caller name to SIP header
I have just setup a new SIP trunk with a local provider and we need to have the caller name added to the SIP packets.  Here is our sip profile.
voice class sip-profiles 1
request INVITE sip-header To modify "@.*>" "@siptrunking.bell.ca>"
request INVITE sip-header Contact modify "@" ";tgrp=calgary_01_403XXXXXXX;trunk-context=siptrunking.bell.ca@"
request INVITE sip-header SIP-Req-URI modify "XXX.XXX.XXX.XXX" "siptrunking.bell.ca"
request INVITE sip-header P-Asserted-Identity modify "(@.*)>" "@domain.com;user=phone>"
request INVITE sip-header Diversion modify "@.*>" "@siptrunking.bell.ca;user=phone>"
request INVITE sip-header From modify "(@.*)>" "@domain.com;user=phone>"
Calls are going through with this and the following packet is being sent out.
Sent:
INVITE sip:XXXXXXXXXX@siptrunking.bell.ca:5060 SIP/2.0
Via: SIP/2.0/UDP XXX.XXX.XXX.XXX:5060;branch=z9hG4bK1E09D1DFF
From: <sip:XXXXXXXXXX@domain.com;user=phone>;tag=1090D060-117C
To: <sip:XXXXXXXXXX@siptrunking.bell.ca>
Date: Fri, 09 Jan 2015 17:36:39 GMT
Call-ID: E727526B-975C11E4-A890855A-8E44E530@192.168.202.54
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  900
Cisco-Guid: 0015978767-2802909515-2130729220-0167905803
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1420824999
Contact: <sip:XXXXXXXXXX;tgrp=calgary_01_403XXXXXXX;trunk-context=siptrunking.bell.ca@192.168.202.54:5060>
Expires: 180
Allow-Events: telephone-event
P-Asserted-Identity: <sip:XXXXXXXXXX@domain.com;user=phone>
Content-Length: 0
We need to have the From and the P-Asserted-Identity changed to
"Caller Name" <sip:XXXXXXXXXX@domain.com;user=phone>
Does anyone know how to do this?
have you set the name for each DN? if so, it has to go out thru SIP Trunk.
if you want to set same caller name for all the calls, you can do it by SIP profile as below
request INVITE sip-header Remote-Party-ID modify "\"(.*)\" " "\"CallerName\" "
request INVITE sip-header From modify "\"(.*)\" " "\"Caller Name\" "
//Suresh Please rate all the useful posts.
Is there a way to add the Caller ID when there is no caller id set in the invite ?
In our case we use UCCE dialer and there is no caller id set ?
It's working when we have a name in the invite:
INVITE sip:+14184444444@gw.domain.local:5060 SIP/2.0
Via: SIP/2.0/TCP 1.1.1.1:5060;branch=z9hG4bK69067a77f03d
From: "Myname" <sip:123456@1.1.1.1>;tag=35371~9f103432-f4c8-464a-a5f1-97eba91dbe7c-34127921
To: <sip:+14184444444@gateway>
Date: Thu, 16 Sep 2021 15:46:40 GMT
Call-ID: 4743f580-1ed13508-638e-977c1f0a@1.1.1.1
But Dialer don't send any names and it don't work.
INVITE sip:+14184444444@cdngw-stadc-sipha.capitaledev.local:5060 SIP/2.0
From: <sip:123456@1.1.1.1>;tag=35371~9f103432-f4c8-464a-a5f1-97eba91dbe7c-34127921
I tried many thing but no chances.
SIP-Profile Test Tool (cisco.com)
Do you know the number that the UCCE presents as the calling number? If so you could create a SIP profile that matches on that number and add a static name.
That would look something like this.
voice class sip-profiles 10
 request ANY sip-header From modify "From:(.*<sip:123456@.*>)" "From: \"Fixed Caller Name\" \1"
 response ANY sip-header From modify "From:(.*<sip:123456@.*>)" "From: \"Fixed Caller Name\" \1"
 request ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*<sip:123456@.*>)" "P-Asserted-Identity: \"Fixed Caller Name\" \1"
 response ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*<sip:123456@.*>)" "P-Asserted-Identity: \"Fixed Caller Name\" \1"
Putting this in together with your provided output, with an added line for P-Asserted-Identity gives this result in the SIP test tool.
If you change the number to anything but "123456" the profile will not get a match.
Response Signature
Ayodeji Okanlawon
You just configure the ASCII display name on the DN, you don't need a sip profile for this.
Please rate all useful posts
