12-17-2012 04:54 AM - edited 03-16-2019 02:45 PM
Dear all,
I want to ask if it is possible to add someone manually to ongoing Meet Me conference. I mean if the Meet Me conference is going on, I want to dial out to add someone to the conference.
Is this possible or no?
Solved! Go to Solution.
12-17-2012 05:02 AM
Hi Muhammad,
You could dial out to the desired party and then Transfer
them into the ongoing MeetMe Just tried and and it
worked like a charm.
Cheers!
Rob
"Celebration it's around us, every nations, all around us.
Singin' forever young, singin' songs underneath that sun" - K'naan
12-17-2012 05:02 AM
Hi Muhammad,
Cheers!
Rob
12-17-2012 05:57 AM
Dear Rob,
You are right. I used another station to dial out a number and then transferred the call to Meet Me conference and it worked.
12-17-2012 05:58 AM
Just wondering if it is available as a feature in Meet Me to hold the call and add people to it.
12-17-2012 06:14 AM
Hey Muhammad,
Good stuff my friend
Sure...you can put the original call to the MeetMe on hold
and then add participants via the method we just spoke about
or even via using new call and setting up an Ad Hoc conference
and then transferring the calls to the ongoing MeetMe. You might
want to check this parameter before using "Hold".
Service Parameters of CUCM
Suppress MOH to Conference Bridge : This parameter determines whether music on hold (MOH) plays to a conference when a conference participant places the conference on hold. Valid values specify True (the system does not play MOH to the conference when a conference participant presses the Hold button) or False (the system plays MOH to the conference when a conference participant presses the Hold button).
This is a required field.
Default: true.
Cheers!
Rob
12-17-2012 08:21 AM
Thank you Rob. It was really helpful.
