DSP Expansion on 2811
Giovanni Ceci
Hey Everyone,
I have a client who has a 2811 Voice Gateway with two T1 cards inserted and two PVDM2-16s installed. The 'sh diag' output is attached.
Now I know there are no available PVDM slots as the 2811 only has 2. I was wondering if there is a way to add more DSP resources in this scenario. Our client needs more transcoding resources.
Thanks very much,
John
2 Accepted Solutions
clileikis
Level 7
Level 7
Hi Giovanni,
You can either replace one of the PVDM16 modules with a larger one, or purchase an NM-HDV2 module and insert additional DSPs on the module and insert it into the chassis.
HTH,
Chris
Giovanni,
Yes the 2811 will support any PVDM2 in its two slots, PVDM2-16, PVDM2-32,PVDM2-64
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
clileikis
Level 7
Level 7
Hi Giovanni,
HTH,
Chris
Thanks for the reply Chris. So the 2811 should support a two PVDM-64s?
Giovanni,
