Bookmark
Subscribe
1127
Aggregating UCS C220M3 server interfaces
Hi Every one,
I would like to know how can we aggregate two interfaces of the UCS c220 M3 server.
2 Accepted Solutions
in vSphere networking under the vswitch properties configure NIC teaming accordingly, you still need etherchannel to balance on the switch side.
HTH,
Chris
Like Chris said you will need to set the NIC Teaming on the vSphere switch and an etherchannel on the Cisco (or other vendor) switch.
Example:
vSphere NIC Teaming:
Load Balancing: Route based on IP hash
Network Failover Detection: Link Status only
Notify Switches: Yes
Failback: Yes
Cisco Switch Etherchannel:
interface gig 0/1
channel-group 1 mode on
Yosh
HTH Regards, Yosh
Chris Deren
Put them into an etherchannel on the switch.
Chris
isnt there anything on the server for this configuration
HTH,
Chris
Example:
Failback: Yes
interface gig 0/1
Yosh
HTH Regards, Yosh
