12-18-2018 03:01 AM - edited 03-17-2019 01:51 PM
I am trying to setup Alcatel IP touch phone 4018 with
But it gives error no tftp response.
Those phone works good with other switches
Let me know any solution
12-18-2018 03:34 AM
Have you compared exiting Switch configuration with SG300, make sure you have DHCP relay setup properly.
If you Phone getting DHCP IP and Options setup for the IP range in DHCP, worth looking the config side.
12-18-2018 04:15 AM
Let me checkout and see. Will update if it worked
01-05-2021 01:55 AM
I have same problem... what is the remedy for this
08-06-2022 10:20 AM
08-06-2022 07:12 PM
The DHCP is on OXO/OXE ?
When I have DHCP on my OXE/OXO with switch port configured with proper voice and data Vlan it worked always.
