Alcatel ip phone 4018 give error no tftp response Cisco SG300-28 28-Port Gigabit Managed Switch
hital
I am trying to setup Alcatel IP touch phone 4018 with
But it gives error no tftp response.
Those phone works good with other switches
Let me know any solution
5 Replies 5
balaji.bandi
Have you compared exiting Switch configuration with SG300, make sure you have DHCP relay setup properly.
If you Phone getting DHCP IP and Options setup for the IP range in DHCP, worth looking the config side.
BB
Let me checkout and see. Will update if it worked
Jerry K J
I have same problem... what is the remedy for this
Jerry K J
The DHCP is on OXO/OXE ?
When I have DHCP on my OXE/OXO with switch port configured with proper  voice and data Vlan  it worked always.
Response Signature
