All outgoing calls going on hold as soon as call answered
NIGEL PAYNE
Hopefully someone out there knows the quick answer to this
I have a user with a Cisco 7965 phone and a 7914 port expansion module
The user reports that each time they place an outgoing call ( internal or external ) it immediately goes 'on hold' immediately after the called party answers
The user then just presses 'Resume' and all is OK
The version of CM is 7.1.5.33045-3
The users phone has FW level :- SCCP45.9-3-1SR2-1S
Is this simply a firmware bug
As this FW level is set across all 7965s in enterprise I would not have thought so ?
Hi Nigel.
Does the ip phone behave correctly if you remove the expansion module and its configuration?
Let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Your doubt may be correct
Also I think it is fw issue
Haitham
