04-18-2024 01:00 AM
I have headset Bluetooth paired with cisco phones and working fine, but auto answer not work.
I tried to enable Auto answer with headset on DN but still any incoming call on phone not auto answer, is there anything I miss other than configure auto answer under DN
04-18-2024 07:39 AM
As far as I know, you need to activate the microphone button on the phone for it to function as you expect.
04-18-2024 09:05 AM - edited 04-18-2024 09:07 AM
Do you mean button have label headset with arrow on phone, I press that button but the line open through speaker when I pressed
04-20-2024 01:47 AM
Support please
04-20-2024 04:37 AM
If you tell us what type of phone you have it would be much easier for us to help you.
04-20-2024 06:12 AM
Cisco 8861
04-20-2024 06:59 AM
04-20-2024 08:47 AM
I press this button but nothing change, the button not light-up, only the line open like I will make a call
04-20-2024 10:58 AM
That is expected, you’ll need to press the headset button and then end the call attempt by pressing the soft key button. This should get the button to stay lit.
04-20-2024 12:56 PM
04-20-2024 06:05 PM
As @Roger Kallberg suggested, you need to activate the headset by pressing the headset button. To terminate the call attempted, use the soft key button.
04-20-2024 10:25 PM - edited 04-21-2024 06:14 AM
When I press headset button it shows to me on screen New Call and then I press End call button also I tried with softkey cancel but no light-up on handset
04-23-2024 04:42 AM
up
