Answer phone
matee
I have headset Bluetooth paired with cisco phones and working fine, but auto answer not work.
I tried to enable Auto answer with headset on DN but still any incoming call on phone not auto answer, is there anything I miss other than configure auto answer under DN
12 Replies 12
As far as I know, you need to activate the microphone button on the phone for it to function as you expect.
Response Signature
matee
Do you mean button have label headset with arrow on phone, I press that button but the line open through speaker when I pressed
matee
Support please
If you tell us what type of phone you have it would be much easier for us to help you.
Response Signature
matee
Cisco 8861
This button is what @Nithin Eluvathingal refered to.
Response Signature
matee
I press this button but nothing change, the button not light-up, only the line open like I will make a call
That is expected, you’ll need to press the headset button and then end the call attempt by pressing the soft key button. This should get the button to stay lit.
Response Signature
As @Roger Kallberg suggested, you need to activate the headset by pressing the headset button. To terminate the call attempted, use the soft key button.
Response Signature
matee
When I press headset button it shows to me on screen New Call and then I press End call button also I tried with softkey cancel but no light-up on handset
matee
up
